X570 / AM4 ASUS ROG Crosshair VIII Impact - a Mini-DTX SFF powerhouse...?
Discussion in 'AMD MoBos' started by Boil, May 27, 2019.
  1. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
  2. mda
    mda [H]ard|Gawd
    1,638
    Mar 23, 2011
    Not particularly interested in this one as I prefer the ATX sized boards, but for the sake of curiosity, will these fit cases that are 'ITX' but not 'MATX'?
    Based on a quick read, Mini DTX is slightly larger than ITX.
  3. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
    Mini-DTX should fit any Micro-ATX case, but might have clearance issues with some Mini-ITX cases...
  4. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
  5. MotionBlur
    MotionBlur [H]ard|Gawd
    1,636
    Mar 27, 2001
    Looking forward to the Formula version, knowing they have EK waterblocks on them already saves me time.
  6. somebrains
    somebrains Gawd
    741
    Nov 10, 2013
    The draw of Crosshair 7 for me was both nvme drives direct to CPU and 4 ram slots.
    I'll look forward to sff extreme builds as entertainment.
  7. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
    Only two RAM slots on the Impact board...
    Apparently, with two sticks of RAM, the memory subsystem will support 3200, but if you go to four sticks of RAM, the built-in memory support drops down to 2933...?
    Unless ASRock comes out with a nice Enthusiast DTX board, the Impact is the one I am going to go for...
    What would make "a nice Enthusiast DTX board", in my eyes...?
    Take the ASUS DTX board, strip the DAC & the DIMM.2 slot...
    Have one PCIe 4.0 x4 slot in the first position & one PCIe 4.0 x16 slot in the second position...
    Make the ASRock DTX board "Thunderbolt 3 Ready"...
    Include a unique AIC (Add In Card), which has two M.2 NVMe slots & a TB3 port...
    Drop this theoretical ASRock board into a NCASE M1 with a 3900X 12C/24T CPU & a Radeon 5700 GPU...
  8. somebrains
    somebrains Gawd
    741
    Nov 10, 2013
    64gb+ content creation workloads is where HEDT is the only option if someone is making $.
    I've seen too many simpler editing jobs eating 16gb-32gb across 3 nvme drives....much less a front line hard core content creation box.
  9. Aluminum
    Aluminum Gawd
    672
    Sep 18, 2015
    Any ITX case with two backplate slots for a GPU will take this "Mini-DTX" board, only the truly small single-slot cases will not. Its smaller than the old shuttle DTX boards from a billion years ago, if anyone remembers from the early days when SFF basically meant Shuttle Form Factor.
    That said, I am eyeballing the Asrock board myself, because thunderbolt n stuff. They also went with LGA 115x bracket holes which is an interesting way to maximize usable board space, all aftermarket coolers worth buying support both anyways.
  10. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
  11. Nobu
    Nobu 2[H]4U
    3,231
    Jun 7, 2007
    It's got two fans over the vrm... that's hot...
  12. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    21,513
    Sep 13, 2008
    it's cooling both the chipset and VRM's.
    "Comprehensive thermal design: An active VRM and chipset combo heatsink and full-sized aluminum backplate with heatpipe add mass to help absorb more heat"
  13. Nobu
    Nobu 2[H]4U
    3,231
    Jun 7, 2007
    yeh, was just trying to be punny. They had a similar design for some intel boards.
  14. Gamer X
    Gamer X Limp Gawd
    347
    Jul 5, 2019
    I think I am going mATX or DTX on my x570 build. I have to wait and see all the x570 boards are released & at this point it is information overload. But my pocketbook is ready.
  15. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
    There is a whopping total of one mATX X570 motherboard (the sub-par ASRock X570M Pro4), and ASUS online support feels the cost & release date for the C8I is a matter of National Security...
    I am hoping it coincides with a water-cooled Sapphire Toxic Navi gpu...!
  16. JRZoid
    JRZoid [H]Lite
    91
    Feb 1, 2019
    pci 4.0...can't even be saturated....not even close to that bandwidth....
  17. 123Lanoix
    123Lanoix 2[H]4U
    3,866
    Nov 13, 2005
    i want this motherboard when will it be available for purchase?
  18. Astral Abyss
    Astral Abyss 2[H]4U
    2,660
    Jun 15, 2004
    That's the million dollar question. I'm quite interested in this mobo for my NCase M1 but not holding my breath it drops anytime soon.
  19. Dan_D
    Dan_D [H]ard as it Gets
    54,645
    Feb 9, 2002
    It absolutely can be. If you can't figure out how to do it, you aren't being imaginative enough. It would be very expensive to do but grab a crap ton of PCIe Gen 4.0 SSD's and its easy. RAID them together and benchmark them. That will do it. That said, it isn't something you can easily do in the real world, and it won't be done with graphics cards anytime soon.
  20. Jandor
    Jandor Limp Gawd
    207
    Dec 30, 2018
    Let's be clear : this is a very poor design made by Asus.
    Mini-DTX are supposed to have 2 PCIe slots and able to receive 2 standard cards. AND of course could very will have several M.2 slots.
    So this board was probably supposed to be a mini-ITX but Asus couldn't handle all the chips of the X570 plus the cooling, so Asus made it mini-DTX.
    The mini-DTX cases (and mini-ITX cases are many to be mini-DTX in fact) have 2 brackets for PCIe cards.
    In this case a real mini-DTX x570 motherboard should include 2 PCIe x16 slots. What they will be for, as many GPU have a thickness of 2 slots ? For those GPU that are 1 bracket thick (there are plenty and especially the professionnal ones).
    So get a real mini-ITX with M.2 slots for your SSD/optane.
  21. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
  22. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
  23. Boil
    Boil [H]ard|Gawd
    1,384
    Sep 19, 2015
    US$430 from Newegg...
    WTF ASUS...?!?
    Price needs dropped by at least 50 bucks...
