X399 and Server 2016
Hammer!
Hi, is there a way to install the AMD X399 chipset drivers on Server 2016? It seems the installer just hangs/closes. When I re-try, it says an instance is already running...Thanks so much!
Hammer!
You can install them by inf files manually. (In Device Manager )
Thanks. I downloaded the driver again and it now installs properly, although I am still not seeing the Ryzen Balanced Power Plan which was my main reason for trying the new chipset driver given the reported performance gains. Anyone else using TR with Server 2016 who is able to get the Power Plan installed?
