no, not really, they just use less power annd are rated for servers and theyll last longer in a server enviroment and are more server oriented, these processors arent really ment to be used solo, but they will work absolutelly fine, just the q6600 is faster for the same price?
Q6600 is not yet available cheaper than those prices. The price for a X3210/1000 is $224 vs $266 for the Q6600/X3220, and should be coming down even more. Even MWave is showing just over $300 shipped for me vs $270 for the X3210 - $30 can go a long way with current tech prices.no, not really, they just use less power annd are rated for servers and theyll last longer in a server enviroment and are more server oriented, these processors arent really ment to be used solo, but they will work absolutelly fine, just the q6600 is faster for the same price?
I wonder which mobos support this chip, I looked on Intel's website and they aren't supported on my badaxe 2 even though it's socket 775.
Good price though.
I'm assuming quads would fsb peak around the mid-midhigh 400's. So for 8x, that'd net about 3.6 or so ghz. Even then, it'd probably require an ass ramming amound of vtt. I've never had to raise vtt for conroes up to 500fsb.
Xeons are NOT made for everyday home use, like C2D and C2Q.
They are meant to handle loads of repetitious work in servers only.
You'd be very lucky to get more than 8x400 with this one.
Ahem, bwahahahahaha....Xeons are NOT made for everyday home use, like C2D and C2Q.
I honestly don't know how you can keep a straight face when typing something like this....
I almost fell out of my chair laughing just reading it...
Theres a G0 stepping version too.http://processorfinder.intel.com/details.aspx?sSpec=SL9UQ
105W - same as B3 Q6600, but higher than G0 Q6600 @ 95W.
Edit: $244.37 (though a weak $19 s/h) - $10 GCO ~= $255 shipped. C'mon NewEgg, I need one of these bad boys down to $250 shipped....
Way to read 4 posts up.... (& cheapest s/h for me was $17)NCIXUS has them for $228 plus shipping ($10 I believe) so $238 total.
Since NewEgg doesn't seem to want to stock the X3210, I may go elsewhere... save some $$$ from NE's $300 they want for the X3220 (and the fluctuating Q6600). TheNerds.net would save another $5 using GCO....
Dude! They changed the specs on the G0: 100W / ThermSpec - 85*C.Theres a G0 stepping version too.
Way to read 4 posts up.... (& cheapest s/h for me was $17)Since NewEgg doesn't seem to want to stock the X3210, I may go elsewhere... save some $$$ from NE's $300 they want for the X3220 (and the fluctuating Q6600). TheNerds.net would save another $5 using GCO....Dude! They changed the specs on the G0: 100W / ThermSpec - 85*C.
-bZj
