Hi,
I wanted to get everyone's opinion on RAM. I'm planning to upgrade to x299 / 7820x in the coming week and was wondering if 16gb (4x4gb) would be the best move right for primary gaming. I'm eye balling DDR4 4000 which is quite expensive so I'm limiting to 16gb or would it be better to drop to like 3600 and try to get 32gb? Would getting the DDR4 4000 be worth it or is the lower timing better for gaming? What speed / latency would you recommend for max gaming performance?
Thanks
Thanks
