Right at x264.nl. Revision 1471 x64.
It's a bit of a bitch to use because your whole encoding pipeline has to be 64-bit for it to work.
Which would you recommend? clear, kGIT or kMod? There doesn't seem to be any explanation there about which is recommended.Komisar's builds are also available, but these are built by with optimizations for Core 2 and newer CPU's for that little extra edge.
With that said, I personally haven't found a need for any current patches (in the past, yes) so I just use the his 'clear' ones.Explain of my builds:
•clear: clean GIT version without any patches
•kGIT: clean GIT version with only hrd_pulldown_interlace patch.
•kMod: all above plus many additional patches (may vary).
