nameBrandon
- Aug 4, 2012
Hey guys.. I've used a few calculators and read some articles, and getting somewhat conflicting info on if this PSU is capable of handling my system.
The PSU is this one..
Seasonic X-560 80PLUS Gold
http://www.seasonicusa.com/NEW_X-series_560.htm
Currently I'm running a GTX 670 and 3570k @ 3.8GHZ with an H80 cooler. Not much else is in the system, onboard LAN, USB mouse / kb and Fiio amp (e10) for audio.
I'd like to swap it out for a couple of older ATI Radeon's, I'm looking at the 6950's. Looks like max draw under load for those guys is ~256W (source - http://www.bit-tech.net/hardware/2010/12/16/ati-radeon-hd-6950-review/10). I'm going to be altcoin mining with this setup, so load numbers are important.
I've got all the power cables plugged into the motherboard (forgive my lack of PSU knowledge), the big honkin one and the two smaller ones.
The 6950's take 2 pci-e 6 pin's each.. I have one cable that splits into two from my PSU right now (running the GTX 670), and it looks the GTX 670 came with 2 cables that take 2 molex and merge down to 1 6pin, so I think I can use both of those cables (4 molex = 2 x 6 pin) or find another spare Seasonic cable that runs from the PSU directly into 2 6-pin connectors.
Question 1 - Am I OK with this 560w PSU? Can it handle the CPU + 2 6950's?
Question 2 - What's the best way to get the second set of 2x PCI-E 6 pin connectors to the 2nd card.. are the molex cables OK, or should I just see if I can find an extra PSU cable like the one that it came with (that splits into 2 6-pin connectors).
Including a screenshot of the specs from the Seasonic PDF for reference. X-560 is mine.
