HyperTension
- Dec 23, 2002
Well, as the title said, I trialed the new beta drivers directly from the nVidia site. Did the normal route to clean old WHQL drivers (uninstall, then CC) and recieved an error on the "installing video drivers" that it was unable to install. Cleaned those off, installed the 285 WHQL drivers (previously running with no issues what-so-ever) and noticed that I no longer had the option for SLI.....
Reboot.. unchanged
Just unistalled drivers via CP... reboot... native VGA drivers installed, check on DM, and only a single 570 shows up....
Power down, reseated, power back up and unchanged...
Went to single card, swapped out cards, both work. Swapped out power lines, both work
Another attempt at the drivers.. Unchanged
Backup OS, Fresh format / install of W7.. Still unchanged.... (Yes, I made sure I had the SLI bridge attached). DM still shows a single 570. Looked at the seating to make sure it's secure on the mobo.. yup....
This is really irritating.. I'm not sure what happened. I've gone so far as to update the BIOS (E689_A05) and I thought there was a spot on the BIOS were I could switch PCI-E as primary video out, but I can't seem to find that. Hardware is in the signature. Any help is really appreciated.
Reboot.. unchanged
