WTB: Working 386 dx40 Complete Systems
BleemZ
'ello,
Title pretty much says it all, I need 386 dx40 working systems.
They would be for some legacy systems that my boss works with.
PM me even if you only have ideas of where to look.
Thanks!
Less than a week ago, my company threw away ten or more 486 and Pentium (<150MHz) PCs.
I assume your requested systems are needed for some special legacy application. Do you have any other requirements? Such as:
Do they need to be EXACTLY a 40 MHz 386-based system, or is anything over that acceptable? (486DX2/66, 75MHz Pentium?)
If you need multiple units, do they need to be identical?
Does a tower or desktop matter?
Any RAM size requirement?
Is a hard drive needed?
Do you need several serial ports?
Do you need full-length ISA slots for a particular interface card?
Awol
Awol-
There are no Ram requirements, no HD is fine. The requirements would be 386 or 486, with 3 parallel ports. They don't need to be identical, and any working systems will pretty much do.
The systems are used for an old lighting system, crown lights, scrolling marquee etc.
Thanks!
