brycejones
- Jan 29, 2002
Title says it all, I know there aren't a ton of options, but hopefully someone has something. Otherwise I'm rig something up. CPUs are L series so the TDP is only 50w each. Water cooling really isn't an option since this is going to be in my Norco storage server.
I'm looking to hopefully get something cheap (or less than new at least) for such an old platform. New is way overpriced. The case is a 4U server case.
Also looking for 4-8GB of DDR2-667 FBDIMMS. The board is an Intel 5000PSL. Memory purchased
I need to finally get my home server back online and get some more D going at the same time.
As for limitations, total budget is in the $75 range for coolers and memory. I can go a bit higher depending on whats out there.
