Meleniumshane90
- Feb 11, 2009
Looking for a GTX 1060. I have a budget of $220.
** I'll consider a GTX 1070 as well
I want the cheapest 5.1 sound card available that works with Windows 10 64-bit. It needs to have the analog 3.5mm 5.1 outputs. An optical SPDIF output is a plus. I'm looking for $15 and under here.
Blu R1 HD 16GB or a Life One X2 64GB -- I just cracked my R1 HD, so I'm inclined to grabbing another if the price is right.
Also, anyone selling TP-Link Smart Outlets, I'll buy for $10 each. I would buy at the $5, but I don't need more Echo Dots.
Cheap SATA III SSDs for spare builds. 120GB for $35 or less, 250GB for $55 or less. I just need them for booting Windows. Preference on newer non OEM SSDs (Samsung, Sandisk, etc)
I need a couple of cheap 500+W 80+ Bronze or better PSUs -- preferably bundled with the above & preferably a modular EVGA. Max budget for both PSUs is $100. Ended up getting a great deal -- $50 shipped for a 650W 80+ Gold EVGA Semi Modular.
I have a 650W G2 that I can't locate the cables for, so if anyone has any SATA and MOLEX modular cables from their EVGA power supply, that would be great. I can toss $15 shipped for this.
Heatware: Meleniumshane90 | Location: Port Richey, FL
