WTB Combos
Status
Not open for further replies.
thrash408
Hey guys, i helped the nephew build a computer a year ago and the CPU/Mobo is having issues. I'm in the market for a good cheap mobo,cpu,memory combo. He currently has i5 and 8gb, so i'd like to stick to that or better. I'm ok with some older chips, as long as it's in the range of 2500k or newer. Let me know what you have and what you want for it. Thanks!
Jsalpha2
Quote "the CPU/Mobo is having issues" If you can find the problem and fix it you would save money. Would be glad to help.
Common culprits:
Heat...re-apply thermal compound.
Power...try a different power supply
RAM...run Memory test overnight
Good Luck
kakureru
Common culprits:
Good Luck
Ive personally have also had issues where the HDD was going bad.
Status
