What else do I need to check to enable wds and wpa at the same time.
So far I've added the MAC address under WDS for both. Same SSID, not broadcasted, same channel, WPA-AES, but it doesn't work, when I switch to WEP it just starts working.
I fnally got it to work with wpa and the results are kind of weird. With WPA-AES, it does not work at all. I've tried a lot of stuff and finally gave up. WPA-TKIP, works for awhile, but then it seems to drop out more than half the time. I'm basing this on a ping -t result. And so far, if I do WPA-TKIP+AES, it seems to be the most stable. Most of the pings go through. About 1 out of 15 don't go through. Can someone let me know if this is typical of wireless connections?
