wrt54g settings??
Discussion in 'Networking & Security' started by antok86, Oct 26, 2007.
  1. antok86
    antok86 [H]ardness Supreme
    7,891
    Feb 26, 2006
    how do i assign static ip to differnt devices on here. was able to on my netgear and dlinks that let me clone the devices MAC id and assign an IP. how can i do this on hte wrt54g?i dont see any LAN settings at all.thanks
    EDIT:
    or are you supposed to STATIC IP it on the device it self (ps3, nas, pc etC.) and the router will detect it?
  2. jcmuse
    jcmuse Limp Gawd
    329
    Feb 10, 2006
    Yes.
  3. antok86
    7,891
    Feb 26, 2006
    so theres no manual settings to assign a mac id to a specific IP. its all done on the device and not router. right?
  4. YeOldeStonecat
    YeOldeStonecat [H]ardForum Junkie
    11,330
    Jul 19, 2004
    I don't believe it supports "reservations" with default Linksys firmware. However...depending on which version you have..flashing with some better 3rd party firmware will give you that feature. DD-WRT, Hyper-WRT, Tomato, etc.
  5. antok86
    7,891
    Feb 26, 2006
    i have wrt54g v8. i went to dd-wrt website..but i was totally lost lol
  6. antok86
    7,891
    Feb 26, 2006
    i found the link which had the files for flashing wrt54gv8. but i dont get the intstructions to well...if anyone can help me thanks
  7. Monkey34
    Monkey34 [H]ardness Supreme
    4,961
    Apr 11, 2003
    Well, I didn't do it on your particular router, but I would suggest reading it completely, keeping a copy of the steps locally (printed or on file), and always remember - it might brick the router. Other than that........my flash worked fine. DD-WRT has a ton of options. Only, in the directions I used, there was a syntax error in one of the commands, so a little linux experience helped me through it.
  8. jonathonball
    jonathonball [H]ard|Gawd
    1,430
    Sep 23, 2005
    http://www.dd-wrt.com/wiki/index.php?title=DD-WRT_Docu_(EN) even has a few guides with steps you can take to possibly revive a bricked router after a bad flash.
    No guarantees of course, but when I flashed a router for the first time I was glad to read-up and have some kind of safety net.
