needsnumbers
- Jan 10, 2007
Well here's me problem. I have 2 switchs that I'd like to use to expand the number of computer hooked up to the internet. One is an older (large case) Netgear FS105 that has a button for uplink/normal operation. The other switch is a brand new Netgear GS605 gigabit.
My WRT-54G has the latest tomato firmware on it and with deviced plugged directly into the back, no problems. Trouble comes when I try and hook up a switch, then a computer. I haven't tried hooking up a different computer (just mine) so that's something I'll try but for the life of me I can't get anything to work. Sometimes the network icon in the systray says acquiring address, but no packets are sent or received! Sometimes the icon jump on and off saying network cable unplugged, not, is, not, is, like a freaking blinking LED.
The router has the default DHCP server enabled and I've tried setting my computer to auto and static IP. Nothing works and if I unplug the switch and try and plug the computer directly into the router like it was, nothing works, required a reboot. The motherboard is an ASUS P5B-E with the Alltansic gigabit, no strange protocols, not even QOS is enabled on the computer!
Very frustrated and pulling my hair out with this one. Any help would be appreciated.
