wrong modem drivers causing lock up?
Discussion in 'Networking & Security' started by ThePriestMike, Sep 25, 2006.
  1. ThePriestMike
    ThePriestMike 2[H]4U
    3,491
    Apr 20, 2001
    can the wrong modem drivers cause a system to hang and lock up? i replaced a bad mobo in a friends system and when reinstalling things i think i installed the wrong modem driver. system is win2k and it is a v92 pctel modem .. there were a few drivers so i just picked the first one. it works about 50% of the time so i can not imagine it being the problem.
    the first time you try to dial out (via netzero) the system will lock up. once you restart it and trry to dial out again it works fine.
    any ideas? thanks
  2. LoStMaTt
    LoStMaTt 2[H]4U
    3,185
    Feb 26, 2003
    Yea defeintely either pick up some new drivers or a new modem.
  3. ThePriestMike
    3,491
    Apr 20, 2001
    tried a newer driver and seems to of solved the problem .. just wanted to double check with some who know more than me before i started messing with stuff
    thanks
