Tsumi
- Mar 18, 2010
Some of you may have seen my build over in the watercooling forum, with a GTS 420 mounted to the roof of a Cosmos 1000. Well, one of the biggest problems with the case that I found was the lack of fans pushing air into the case, which severely cuts down on airflow. To remedy that, I decided to mod the bottom of my case to add more fans. While I was thinking about it, I decided why not add another radiator as well. I took some measurements, and concluded that a 360 radiator will just barely fit with a standard length ATX power supply, my Seasonic M12D 750.
System specs:
Core i7 920 @ 4 ghz
24gb Patriot Viper II Sector 7 DDR3 1600 mhz
MSI Big Bang Xpower
Gigabyte HD6990
300gb Western Digital Velociraptor
320gb Maxtor
2tb Western Digital Green
DVD burner
Cooling:
MCP655 with XSPC D5 tank (to be added)
Black Ice GTS 420
Black Ice GTX 360
3 Aerocool Silver Lightning 140mm
3 Cooler Master R4 (to be replaced with 2150 RPM Gentle Typhoons in push/pull)
XSPC Rasa
XSPC 6990 Razor
Sorry I don't have any pics of it being taken apart, but here goes.
Here is the initial test fitting. As you can see, there's barely any room between my power supply and the radiator.
You can really see how close it is here. The modular connections are actually underneath the radiator with fans installed. With a fully modular power supply, this probably would not be possible.
The hardwired cables come out to the side of the radiator.
The grill conveniently lined up with two of the screws, so I used that as a guideline for mounting the radiator and the cutting to be done.
Making sure I have enough room for a push/pull setup for when my Gentle Typhoons come in.
System specs:
Core i7 920 @ 4 ghz
MSI Big Bang Xpower
Gigabyte HD6990
320gb Maxtor
DVD burner
Cooling:
Black Ice GTS 420
Black Ice GTX 360
XSPC Rasa
XSPC 6990 Razor
