IS POOPIE!!!
Wow, I must say no other game has even come close to kicking my setup in its digital junk like witcher 3.
basically averaging 19-30 fps with most settings ultra and high, hairworks on the main char only. Both cards showing 90+ % usage and 95% power. Vram usage never went higher than 2700.
Only done a small amount of jacking with the settings but did manage to get something i'd considerable kinda playable @ an average of 30 fps.
Guess ill have to ditch the surround and try 1920 x1080 like I was trapped in 2013 or some other god awful ancient past time I clearly don't remember being apart of.
Using 347.88 driver, as the two released after (including the one with the game ready w3 drivers) do not function correctly with sli and surround....resolutions are recognised incorrectly, nvcp takes 1-3 minutes to repsond to almost every change you make...
I have not actually tried to run the 352.86 driver with witcher 3, as anything in the 35x.xx series of drivers is a massive hassle due to what I typed above...
Hmm.
Hmm.
