Boil
- Sep 19, 2015
Sorry AsRock_ , I have been doing more reading on the old Interwebz...
So, would you please, Please, PLEASE push for the following Enthusiast X570 ITX motherboard...?!?
AM4 socket
X570 chipset
Ample power phases for Ryzen 9 3850X CPU
64GB maximum RAM
(2) DIMM slots w/ support for 32GB DDR4-3200 CAS 14 DIMMs (ECC support as well)
NO onboard video support
Chipset moved to bottom rear corner of motherboard (like with the X299 ITX motherboard)
Front side 2280 M.2 slot (like H270 / H370 / Z270 / Z370 motherboards) that is for NVMe SSD only, x4 PCIe straight to the CPU
Two (2) rear 2280 M.2 SATA III SSD slots
NO onboard SATA ports, the backside M.2 SATA III SSDs are what you get
Gen 4 x16 PCIe slot
Dual 10Gb Ethernet
USB-C
USB
Audio I/O & Optical
The ASRock X570E-ITX/ac "Little Monster"...!!!
I will be glad to T&E a production sample for you, please include R9 3850X CPU & RAM kit, thanks...! ;^p
AM4 socket
X570 chipset
64GB maximum RAM
Gen 4 x16 PCIe slot
Dual 10Gb Ethernet
USB-C
USB
Audio I/O & Optical
