I can hear very high frequency noises and its terribly annoying if I just want to use my computer for some surfing and I have to play music (fairly loud) to drown it out.
My current stance is to make a shell to sit over the top of the computer, I dont have a case atm.
I'm thinking of buying this:
http://shop3.mailordercentral.com/supersoundproofing/prodinfo.asp?number=09-42760
2x 1 foot by 4 foot section going from one wall to the other
From wall to motherboard edge to 1.5ft by 2ft, and then put a make shift lid from the same roll of soundproof stuff.
Just to clarify, nothing will be mounted to the sound proofing material, this computer will never move, it'd just be something that sits right over it to dampen the noise (hopefully a lot)
Thoughts?
Thoughts?
