dugn
- Aug 16, 2009
I need help and advice that I haven't been able to find elsewhere.
In my Corsair Obsidian 800d case, I'm going to have 2 12" Cold Cathode tubes to accent the motherboard from the side and bottom. I'll also have 3 Logisys 120mm fans on the top with their circular cathodes beaming down from above.
All will be controlled by 3 blue LED Vandal (Lamptron) switches: Switch #1 - will control the 2 tubes, Switch #2 will control the 3 circular fan CCFLs, Switch #3 for later use.
Questions:
Where do I get 3V to run the LED in the switch. I understand the LEDs can only handle 3V, so where do I get a 3V line - or do I need to use resistors to ratchet a 5V line own to 3V?
How do I control the 3 Fan CCFLs with a single switch. How do I rig all 3 fan CCs to run off of a single switch since they all came with 1 switch apiece and 3 individual transformers?
Any other tips?
Since this is my first step into running anything non-standard in my new rig, I wanted to learn any tips or tricks needed to get this right. So far, the FAQs and guides I've seen just step you through installing Cathodes from a kit, or rigging a baybus, but not the details needed to rig 2-3 kits together and drive them off a single switch and step down the voltage to keep LEDs from burning out.
Any tips or instructional links would be greatly appreciated.
Questions:
Any other tips?
