tankman1989
- Aug 21, 2009
I have a modem/router that has wireless and I wanted to make sure the wireless couldn't be accessed on it, so I removed the antenna (which did very little under 120ft) so I figured I would unsolder the connections b/c they had about 8-10 inches of wire attached to them from the circuit board. Well, I'm still getting 85% strength at 70ft for some reason.
This wouldn't be much of an issue except I found a major security issue with these routers which allows the wireless to be turned on remotely via WIRELESS even if you don't have the current admin/root password! I'd get rid of the router but I have to use it for the time being.
Is there anything else that can be done to limit the accessibility to this thing? The solder points on top of the board do not show up on the underside of the board at all (are these things layered? There are some transistors a few mm-1/2 cm from the wifi points.
Anyone have any suggestions for this?
