Wireless RGB Mouse recommendations for big hands/thumbs, lol
Lumpus
Currently using a Logitec G203 and it's alright (good hand feel) but I'm starting to find the cable a bit irritating.
I'm considering the Corsair Harpoon but I'm a little concerned about the two side buttons. The trouble with most 'gaming' mice for me is that my big thumbs are always hitting a side button by mistake and then screw something up. For most gaming mice, the sensitivity seems to be way too high, causing them to be activated on a mere brush-by. At least on the G203, the two side buttons are located just high enough up that my thumb rests safely underneath.
atarione
my hands are pretty big I have a Steelseries sense 310 which I don't have a problem with my thumb hitting the side buttons at all.
Vile
Logitech G703, one of the best mice I've ever used and is amazing when it works, although I am on my 3rd one now.
The only problem with the G703 it's known to have the double click issue or scroll issue but Logitech will RMA it if it happens within the 2-year warranty period.
