Wireless N AP Suggestion
dasaint
Hey all, i am looking for a good suggestion for upgrading my current AP to a newer one.
currently running an Aironet 1200 Series with the G Radio inside of it and i have found it quite lacking to my bandwidth needs.
i am looking for some good recommendations for a replacement in the N Series
Requirements are
Dual Band simultaneous bands
802.11N
Can handle some streaming PAIN
Gigabit connection into it
i know there are routers out there that could do the job but i would like to see what APs are out there directly that could also do the job as i do not need the routing functions.
k1pp3r
Lately i have been using D-Link DAP-2553 Wireless N Dual Band Gigabit Access Point w/ PoE
They have been rock solid and the POE is nice
dasaint
from what i read the DAP-2553 and the DIR-655 do not utilize Simultaneous dual band its either or not both.
Thanks for the info tho.
/usr/home
Kind of a PITA, but you could get a decent 2.4 AP and a decent 5 AP. Annoying having to run two, also the price difference could be a bit as well.
dasaint
Yea i thought about that but i really would rather have 1 device.
