is there a doodad (highly technical term there, be careful with it
) that i can use to transmit wirelessly from my set top cable box to my pc?
set top box is scientific atlanta explorer 3200hd... there is what appears to be a usb port on the front of it... i'm using the dvi port out of the back of it to connect to the tv (dvi to hdmi, fwiw)...
i'd like to figure out a way to do this, so i don't have to run cable to the other side of my living room to get to my pc...
suggestions and wise remarks welcome...
thanks...
