VoodooChi|d
- May 3, 2005
Ok I installed x64 Vista Ultimate on my PC. Almost all the drivers automatically updated except for 2. The sound adapter and the Netgear card. I found the sound adapter driver for Vista online and installed it no problem. After a bit of searching I finally found some beta drivers for the Netgear card on the Netgear website. Included in the zip were drivers for both 32 and 64 bit Vista. After trying to install the 64 bit driver and saying it successfully installed it just gave me a "Code 10 This device cannot start".
I have looked on a bunch of sites and it appears that while the 32 bit beta drivers work the 64 bit ones do not. I don't know what to do because it is nearly impossible for me to run a cable into the room where the computer is. Do I just have to stick it out until the real drivers are released or a revision of the beta comes out?
