Wireless always 'identifying' but internet works fine??
Discussion in 'Networking & Security' started by Betaboy1983, Mar 28, 2012.
  1. Betaboy1983
    Betaboy1983 [H]ard|Gawd
    1,250
    Dec 31, 2008
    I just had a quick question. I have a wireless N adapter on my PC and I have never had any trouble. I switched ISP's and they brought out a new router and now my network always says 'identifying', and will only say 'connected' every 5 minutes or so, and will only stay connected for maybe 2 seconds tops. What I find weird is even when the network says it's identifying the internet works just fine, 25ms ping on speedtest. Signal strength is 4 out of 5 bars. I'm not too concerned since everything works just fine, but I was wondering if anyone knows what is up with this new phenomenon. :confused:
  2. stiltner
    stiltner [H]ardForum Junkie
    11,221
    Mar 16, 2000
    Uninstall network adapter, reinstall adapter.
    Then reinstall drivers
    Reset the ip stack after you do that
    netsh int ip reset resetlog.txt in elevated cmd prompt
  3. Betaboy1983
    1,250
    Dec 31, 2008
    I'll give it a shot tonight! Thanks!
