SomeGuy133
- Apr 12, 2015
Alright so I have 2xR7000 and have 600Mbps 2.4G and 1300Mbps AC set up on 5G
My understanding is to get 1300Mbps it uses 600Mbps 2.4G and 866Mbps 5G to make the 1300Mbps correct?
Why do I only get 866Mbps on my S8 and laptop (Intel dual band 8260AC). Need 4 band?
How do I get AC to work exactly?
Note I picked the best channels given the channels and routers near by and I am 1-10 feet away with direct line of sight and everything appears to be programmed right in the router.
2.4G
There are a piss ton of routers in my area but I live in a house with good walls and only one house is next to me given there is a road, pound, field on 3 sides and a house on the 4th side and each house is on 1/4 acre lot so only like 1 router is actually even remotely close to me so hgihest signal is like -80db or less on 2.4G
???That is a pretty clean airway right if nearest signal is -80db? That is like 1 or 2 networks at -80db to -90db and like 5 or 6 that appear and disappear at -90db
5G is 100% clean
I also have 2 of these in the house. 1 on top floor and one in basement and both get about same signal being 1-10 feet away and on different channels that get 0 interference between my two routers. Like channel 1 and 12 for 2.4 and 5.8 and 5.2GHz for 5G or something like channel 161 and 43 respectively or something.
2.4G signal is -30db to-40db at like 5 feet
5G signal is -30db to -40db at like 5 feet depending on where i set my S8 according to wifi analyzer.
From 5 feet away.
5G=866Mbps(not consistently(400-866)) which is max for 5G
2.4G= 192Mbps max (120-192Mbps) which seems offal.
Also newest firmware is installed.
Any input?
2.4G
5G is 100% clean
From 5 feet away.
Any input?
