Hi all,
I have a question. I was wondering why sometimes file transfers inside my internal network are much slower than usual. Here is my setup. All computers have a 10/100 NIC. I have one main router (4 ports 10/100). My computer is connected directly to that router. Then, from another port on the router, i have a 10/100 full-duplex switch connected. From that switch, I have 3 other computers connected. All cabling is CAT5e. Normal transfers between computer are usually around 7-9 MB/s, which is about 80% of 100 Mbit (which is good). But for some reason, at another time, I try to transfer between the same two computers, and I get like 1 MB/s (not very good). Maybe a couple days later, nothing has changed settings wise, but all of a sudden I get the good 7-9 rate. I just don't get it. Any help is greatly appreciated. Thanks.
SuperG
SuperG
