[WIP] Antek ISK 300-150 AM4 Build
Nobu
Parts:
MB: Asrock B450 Gaming-ITX/AC (shipping)
CPU: A6-8570E PRO (4000-series later, maybe)
Cooler: Noctua NH-L9a-AM4
RAM: TBD (Likely TEAMGROUP E+ 2x4GB 2400 cl16)
Storage: Crucial 128GB SATA SSD, to be upgraded later.
So far I've got the case and CPU cooler. I've unpacked and disassembled the case. It's a lot heavier than I expected, and assembly is funky – you must remove the HDD and FDD trays, and the power supply assembly in order to remove the fan bracket. You probably can't acces the lower screws on the fans with the motherboard installed either, so removing the bracket is required to remove or rearrange the fans. The fan blanking plate has two tabs holding it in place, along with two screws, and the whole thing is plastic, so you need to be gentle when removing it.
Back to the PSU: It's held in place by two screws and four tabs. It's held very securely by the tabs, but getting it under or off the tabs is a PITA. I don't know if it's the FP cables/housing (plastic box up front, behind FP) or the poor routing/strain relief on the power cable coming out the side, but something prevents it from sitting right on the tabs near the front side of the case, and you can't see them so it's wiggle jiggle until it falls in place, then press down on the left side and slide forward.
The Power/Reset/*LED wires are all on the left side...except one. But they're all the same length! I bundled them together and routed them under the PSU power cable, will tie them to the support bracket above the MB... except the short one.
Here's what it looks like, all said and done:
Seems like cable management will be a cakewalk. Some wires may have to switch sides depending on board layout, but looks good to me. Undecided on fan placement
Parts:
CPU: TBD (Likely APU, considering the 3200/3000G)
I have that case for 5 years now as plex server
Nobu
They must have changed the design. That looks completely different – Mine only has a narrow vent on the wide side where the 1/2 height pcie card goes, and the whole length of the narrow sides are vented. It's longer front to back (about 1/2 the width of the motherboard longer), has a bit more room above the motherboard for a cdrom, 2.5" hdds, and an internal PSU.
Edit: You got the ISK 110 VESA, similar, but much smaller and VESA mountable.
Ready4Dis
You may or may not want to wait this long, but the new APU's are coming soon and likely much higher end than the 3200g/3600g with zen2 improvements (curse you AMD for labeling APU's with the wrong generation). Looks like a pretty small case to work in, but should be nice when done. What kind of cooling is available for the case itself?
Nobu
I'm seriously considering it, just I know I'm not going to like the price.
Case has two 80mm fan positions (one occupied by a tri-cool) on one side of the case, with the PSU providing a third. It works kinda like a 1U server, where all the air flows from one side of the case to the other. Wanted a 1U cooler from dynatron, but nobody stocked it for a reasonable price.
If you remove the fan bracket (seen in the background of the photo above) you can barely fit one 92mm fan, but there's no way to secure it to the case without modification (except maybe with zipties). You could fit a second 92mm fan if you remove the power supply, but I don't think a third is possible on that side of the case.
I'm thinking about swapping the PSU with a 160w PicoPSU from mini-box, but they only have 1 molex and 1 sata connector by default, and I'd prefer two sata connectors for this case. There's a header to add another cable, but that would be unnecessary if....
Edit: after measuring, looks like 2.032 92mm fans could fit with the psu still installed, but it'd be really tight.
Nobu
Purchased an A6-8570E PRO off ebay for $35, will hold me over for now. Will probably get a 3300x and an nvidia 1030 (half-height, or a higher end full size card with a riser if I can find one <75W and single-slot) later on, or something better if I can hold out that long.
Tags
am4 sff wip
