WinXP 64Bit Trial Beta.....M6805/M6807???
Threader
Who has downloaded it and installed it on the Emachines M6805/M6807?
WinXP 64-bit 360 DAY TRIAL
Can you make a dual boot? I don't want to lose my current WinXP Home setup.
I am downloading right now and will only install it if the Broadcom wireless, VIA AC97 Sound and ATI 3d Works.
lopoetve
beat me to the post. DLing now. 30min to DL, then give me 2 hrs to install/tweak. I'll report back.
Threader
Are you going to do a dual boot?
lopoetve
Yes. Make a space for a separate partition (partition magic), and then just install. NTldr will do the rest for you.
Kingofl337
Been there done that. My site is getting hammered with the AC97 codec download. Dual booting is easy, but you have to resize you partition or you will loose it. ATI does not have a direct 3d driver for XP - 64. Check out my post in AMD Only to contact ATI and ask for drivers.
lopoetve
install crashes while copying files. will try again, and report back.
This seems to be a regular problem with 64-bit OS's and this system. I can't get a one of them to work. Maybe it's time to take it back for a replacement, I'm still in the 14 days.
EDIT: Nevermind :)
Just didn't give it long enough. LONG pause in copying files. Several of them, for that matter.
lopoetve
That brought it back all but once. One time, it stopped for about 1.5 min, and then went. Mouse frozen, etc, then it went.
lopoetve
It's up. No Audio, no video, no wireless drivers, but it's up.
Audio -> Via Hyperion drivers install, and install the sound set, but it doesn't seem to take. Probably a bug.
Video -> doesn't exist
Wireless -> same.
Kingofl337
I posted AC'97 drivers if you search you will find them. The only reason you don't have video drivers is you haven't bothered ATI enough.
olaf2821
nVidia has drivers up on their site, use an old card for the time being, doesn't sound like you are going to game on it anyway.
N
NecessaryEvil
Guest
"use an old card"
in a laptop?
Threader
Video works. go to drivers tab, Change drivers from default VGA.
Choose your own driversfrom list. ATI shows up.
I chose Radeon 9600 family (no mobile driver) and the best resolution is 1280 x 800. No 1200 x 800 available.
3dmark2001 ran as so di 3Dmark2003. I stopped the bench s short cause it was late. When I get home will bench,
AtiTools did not work. So all benches will be stock.
Will try for sound and wireless tonight as well
N
NecessaryEvil
Guest
but...the resolution is 1280x800, not 1200x800??
Kingofl337
W00t...He is right there are ATi Drivers in XP 64!!! They were hiding uncheck compatible hardware and choose ATI done deal! There is no 1024x768 just 1280x800.
Threader
Yes becuase you have to chose desktop Radeon9600 drivers and since they are not mobile drivers, then I guess 1200 x 800 is not an available option. Maybe an aftermarket screen rez and refresh program can hack the resolution. Not sure if it will work in 64bit Xp. You can always try and let us all know.
For me I'm just overjoyed to get some 3d drivers in WinXP 64 :D
WOOT!!!!!!!!!:p
Threader
HARDOCP Forums SEARCH function disabled.
Maybe this is it
VIA 64bit drivers
DOH! AUDIO does not install. I try even pointing to the Driver file that installs itself to an X86 folder but WinXP 64 refuses to intsall them.
Anyone have any luck intsalling these drivers for audio?
Threader
I would give anything for some Broadcom Wireless Drivers right now. Please post any leads you may have on where and when they could be available for WinXP 64-bit.
Thanks
Kingofl337
hehe E-mail broadcom!
3D Mark Chokes on my laptop in XP64 When it gets to the Battle of Proxicon and Troll Tests.
scatpack
Threader,
Correct me if im wrong but...
Emachines are default at 1280 x 800 not 1200 x 800. Why would anyone want 1200x800 anyway (even though you can't choose it)
Eric1285
Originally posted by scatpack
correct me if im wrong but...
You're right.
scatpack
Im really disappointed.
Its been 24 hrs with WinXP64 and yet.... not one benchmark!
Threader
Ok all numbers are at default drivers and system speeds. No overclocking.
Benchmark programs are the same 32bit programs.
3dmark2001se Emachines WinXP home = 9000
WinXP 64-bit = 7862
3dmark2003 Emachines WinXP home= 2400 WinXP 64-bit = 1489
SuperPI = Emachines WinXP home = 48secs WinXP 64-bit = 47secs
thats it. Need optimized 64bit benchmarking software.
Default Graphics drivers on WinXP 64-bit for ATI SUCK but at least hey work. Like someone said. Some 3dmark2003 tests were zero frame slideshows. Looks like something is wrong with Via AGP of AGTI drivers here.
I look forward to getting upgraded drivers from Windows Update or Emachines in the near future.
Still need AC'97 working drivers.
scatpack
To be honest... thats the performance i expected. From what Ive heard these are definitely a non-optimized version of Xp64 for now.
But that WILL change. When is anyones guess.
lopoetve
Maybe this is it
VIA 64bit drivers
Nope. Couldn't on my first one. I'll try this one again, when I get the partitions and everything right...
Pain in the butt...
Threader
For now only useful drivers for Us m6805/M6807 owners is the GOOD :D AC'97 drivers in their audio section.
WinXP 64 drivers
AC'97 now works great!!
Ok now next Priority is Broadcom Wireless drivers.
Then integrated USB Flash Memory readers
Then low priority Modem
Enjoy!
PS. btw. has anyone noticed how our lappys run at 1800mhz on batteries with WinXP 64-bit ;)
lopoetve
WinXP 64 drivers
Enjoy!
yuck
Kingofl337
There is something wrong with powersaving in XP-64. It checks keyboard/mouse movements and throttles back when they aren't being used. This is the same problem many people have on the install having to keep moving the mouse.
Threader
My install of WinXP 64-bit was smooth and lag free and I never needed to touch my mouse or keyboard to keep the install process moving along. My M6807 happily absorbed the new OS :)
