- May 18, 1997
As always, we want to hear our guys' takes on a product like this. Please take time to read the review posted here before sounding off. Thanks!!
krizzle said:For some reason, as I was looking through the first few photos of the block itself, I got the feeling that it was not made with very good quality. You had to muck up the thermal paste and all... And in comparison to how clean and sleek other blocks look, e.g. dangerden... this one seems kind of sloppy.
robberbaron said:I agree. The copper seemed really rough, but, this is the next best thing to phase change and the results spoke for themselves.
Imagine putting a pelt on the Swiftech Storm.... haha
the DD maZE 4-1 is not any cleaner to put together and install, since it comes in pieces and you have to apply your thermal compound and fit your neoprene yourself during the insall.krizzle said:For some reason, as I was looking through the first few photos of the block itself, I got the feeling that it was not made with very good quality. You had to muck up the thermal paste and all... And in comparison to how clean and sleek other blocks look, e.g. dangerden... this one seems kind of sloppy. Not that you go for looks with a peltier... e.g. your Bike Tube! that was truly cool (no pun intended).
IronChefMorimoto said:I'm too much of a LimpGawd to respond to this article. Incredible stuff. Glad someone has the $$$ to try it out. Why no AMD Athlon64 variants?
IronChefMorimoto
probably only a little more than i enjoy the heat from my 226 and 80 watt combined.101 said:I wonder how people outside of Alaska would enjoy the added heat generated by a 430W pelt?
have a look at DNA's thread.IronChefMorimoto said:I'm too much of a LimpGawd to respond to this article. Incredible stuff. Glad someone has the $$$ to try it out. Why no AMD Athlon64 variants?
IronChefMorimoto
mohammedtaha has it right. the storm only cools the cenrtal area of the block well. using one with a pelt would be pretty silly.robberbaron said:I agree. The copper seemed really rough, but, this is the next best thing to phase change and the results spoke for themselves.
naw, swiftech has the 5002 mated to a pelt and DD has the maze 4 mated to a pelt.Neutraleyes said:Wow, it's been a while since I have read anything about Pelts. It's good to know that people haven't given up on the idea. Seems like the last waterblock with a built in pelt was years ago - the Swiftech MCW462-UHT.
you can't have your cake and eat it too.mohammedtaha said:I actually think that the pins they used was very restrictive and the 2 inlets/outlets a stupid idea.
If they had some form of impingement design such as Cathar's but spread out to provide a wider rush in of water and the outlets taking the water from the far ends then the cooling performance would have increased.
DFI Daishi said:you can't have your cake and eat it too.
to get jet impingement happening, you need really fast moving coolant.
you can get that in a core sized area with a normal pump, so it's a really good solution.
to get the high turbulence region happening over this large an area, it would just take too much pumping power.
cathar posted about this stuff in a thread regarding a direct die cooler, and altough he was focusing on what it would take to get a square centimeter's worth of jet impingement from a single outlet, think for a second about trying to get at least 46 square cm of jet impingement even with multiple nozzels.
his promised VGA block that is pelt compatible?mohammedtaha said:While I was typing this I started to think of the power needed to get it accomplished .. it's not impossible with a "normal" pump, it's all about tackling it different. Cathar will soon get it done .
DFI Daishi said:his promised VGA block that is pelt compatible?
i eagerly await it, however keep in mind that it will most likelly be intended for use with a wee little 40x40 mm pelt, as opposed to a 68x68 mm monster like this.
just indicating that i think it might not be faasible on a pelt of this size.mohammedtaha said:yeah .. well 40x40 is the only way for VGA unless GPU's get bigger. There's no other way around it. We'er also going way off topic ..
I believe I've seen that same pin design somewhere else .. Someone has done the same thing before but I can't recall where.
if you tried to do this with a 226 watt pelt, the assembly would start to cry, and you would cry shortly afterwards, when temps started to climb up to what you would expect from running the block alone.Russ said:So does a 226W TEC give half the cooling? What kind of temps would you be looking at with only a 226W TEC? (Temps on, say, the article's setup @3.96 Ghz as compared to 61F with the 437W.)
dude, do you not know what watts measures?CleanSlate said:226watts seems like it is alot... is that 226watt dissipation per second or per minute or what?
~Adam
well, i tried to answer the part about 226 watts being a lot. i would suggest the repository of knowledge that is wikipedia, if you want to learn aout what watts are. :|CleanSlate said:It was obvious in my post that NO I didn't know what the watts measured, I had an idea though. Learn new things daily.
Yet I never know anything.. oddly enough.
~Adam
