1. Is there a way to enable a dialog confirming log off? I use the classic start menu configuration (I find it much easier to use), with "Log off ..." enabled. However, accidentally pressing this instantly logs the user off, instead of prompting for an OK like XP and earlier. This is really frustrating sometimes. Any advice?
2. Vista is BSODing randomly and at random times. The default Business 32-bit Dell install that came with my laptop was REALLY bad (it would BSOD literally every 15-20 minutes, each time with a different, random error), so I upgraded to 64-bit Business. The BSODs are much less frequent, but they're still occuring sometimes. Most prevelant is during boot or right after logon. I have all the latest updates, including the non-Windows Update reliability ones. There seems to be no pattern to when they occur, and the error is different each time. Has anyone else had similar problems with Dell laptops and Vista?
Other than that my system is running fine. Loving Vista, except for these few little annoyances!
