so i just installed a fresh copy of win2k sp1 onto a computer, formated the drive with the normal installation process. even before i installed anything (including drivers) the cpu usage is bumped up to ~95% in task manager graph. under processes it shows the idle process at 99% and everyhting else at 0. at first i ruled out the possibility of a virus because i had not installed anything and i had not yet plugged in the lan cable. then i noticed that my computer reported 2.11gigs of space being uesd, yet the total size of all the folders on the drive combined is 614megs. is there any way that a virus can 'survive' a format (not a quick format) and still be there with a new windows install?
any help would be great
