DeathLord1969
- Oct 30, 2022
Still waiting to hear back.contacted xfx yet?
I bought that same cable and it changed nothing.Could be an HDMI handshake issue... The old receiver is HDMI 1.3a, which is only 10.2 Gbps and doesn't support 4k. The new tv is 4k.
And, you mentioned that directly connecting to the TV you still experience the issue. Which rules out the receivers as a cause. Which leaves the card, hdmi cables, and tv. It could be a driver issue as well (part of the card).
I would recommend getting a higher bitrate HDMI cable, especially if the cables you have are the same age as the receiver (2008). The receivers' HDMI is old enough that it probably causes both the source and the display to use an older HDCP handshake protocol and/or cause the card/tv to negotiate a lower bitrate connection. So it works when the card and TV are forced to use old HDMI 1.3a.
I use Zeskit 8K HDMI cables from Amazon, and they solved a picture quality issue a friend had when he got a new tv. You might also try setting an FPS cap if the drivers allow that, set 60Hz.
i would second trying this^^^ i looked through the manual looking for something like that but mine is called hdmi standard/enhanced mode and didnt see that...If your system works fine with a similar monitor, it could be that your TV's HDMI 2.0 EDID is corrupt.
Your TV has an EDID switch option in its Setup menu. When connected to your old receiver, Auto should result in HDMI 1.4. When directly connected to your 6600xt, Auto should result in HDMI 2.0.
Your system should see these two settings as two different devices. Try toggling this setting manually and see what happens.
If your TV's EDID option really only switches the EDID presented to the system, you may be able to work around the issue by selecting the HDMI 1.4 EDID on the TV and using CRU to override it manually.
I had already tried the EDID setting on the RCA tv and it made the screen go all weird. So I switched it back to 1.4. 2.0 kinda looks like stretched wide mode.If your system works fine with a similar monitor, it could be that your TV's HDMI 2.0 EDID is corrupt.
Tried that, when I restart the driver, it makes the sound of something getting unplugged. Then loads 1920x1080 with no higher option in display settings. it is still listed in cru.Select the active monitor in CRU. Under Detailed Resolutions, add 3840x2160 60Hz with CVT-RB timings and make sure it is the topmost on the list. Click ok and restart if prompted to. Fire up CRU again and verify the new mode is still there. Finally, attempt to switch to the new resolution.
To confirm that, is that not what I am trying to accomplish here? By using CRU to change the resolution? If you look at the specs for this exact card, it's supposed to be able to do the 38xxX2160 res and the tv supports up to 2160p.Bummer.
If you haven't already, you may want to try all the different HDMI inputs on the TV. Sometimes only one of them is actually HDMI 2.0 capable.
Beyond this, it's probably not worth moving forward until you can confirm the following:
- The 6600xt can output 4k60 4:4:4 to a different display via HDMI 2.0.
- Your TV can handle a 4k60 4:4:4 input from another device.
Any ideas on anything we may have missed?CRU let you test if a single, specific issue was the hangup. It wasn't, so it's time to move on.
