Hi this is a conceptual question here.
On say a normal Windows Dell laptop, if you start a large file or folder copy while on a wireless network, and then mid-way through the copy connect the LAN cable... would you expect the copy speeds to increase?
Presuming here that the LAN wired connection is faster than the wireless one.
Can windows just change over to the LAN connection like that?
I don't think so, but don't have one to test.
