Windows 8 help
Patriot
[H]ard|DCer of the Month - March 2011/June 2013/De
After a nightmarish install... Disabling USB caused it to not boot from the install media.
there was a certain usb emulation mode that I ended up disabling to get the install to stop freezing on disk format.
Key before install... seriously my favorite thing about the 7 install was not having to enter it till after you got it up and running.
Metro has beyond pissed me off ...but that is not my problem...
Hyper-V bricks my OS on install... Gets stuck in an infinite reboot loop :) no bueno.
System in question:
Biostar Tpower X79
E5-2680
8gb ddr3 1600
128gb samsung 830
Sapphire 7970
2x 1.5tb WD black (mirrored)
Asus DGX
Lite-On bluray drive
I have looked around and I see disabling usb3 on gigabyte boards as a "fix" ... Considering I only have 2 usb 2 ports...that would suck and is frankly unacceptable.
Any ideas? I have a clean install of windows 8 back up... but I have not been brick happy today yet.
Edit:
Windows 8 Pro x64
Also of note...
I have a C0 stepping, VT-D was broken in C1 ... I am unsure if it will work on C0 and I have not found any evidence one way or the other.
So, Does VT-D need to be enabled for hyper-V ... its not the sole virtualization tech...that is just for disk IO stuff.
ob1
Are you overclocking in any way? Any bios changes over the default optimized?
Patriot
Its an E5-2680 ....they don't overclock... like at all.
but there really isn't a need to anyhow... 2.7ghz 8c 16t 3.1ghz all core turbo. 12.03 in cinebench...
Sorry that wasn't pertinent...
No, no overclock.
All defaults apart from raid.
and boot order...
Hyper-V breaking shit seems common but I don't see any of the fixes lining up with my configuration.
On gigabyte boards with USB3 disabling usb3 fixed things ...but a later UEFI bios update fixed things as well.
heatlesssun
Extremely [H]
I've seen this problem before and for me it was caused by USB 3.0 and Hyper-V in combination. Disable USB 3.0 if you can in BIOS and see if that works.
Patriot
Is microsoft planning a fix?
Because I have 2 non usb 3 ports... ... and one of my main ssds is off usb3 .
