Windows 8.1: High CPU usage by "System" process when idle
Megalith
24-bit/48kHz
Staff member
Okay, this is driving me crazy. Whenever my PC is left idle for some time, CPU usage by "System" will ramp up. I have no idea what is causing it. I had thought that there was something in Task Scheduler that would run itself whenever my system was left alone, but there is nothing of the sort. I've also tried using Process Explorer to get a more in-depth look at what the heck "System" is, but it's as equally vague as what Task Manager is telling me.
Has anyone run into this?
Megalith
24-bit/48kHz
Staff member
No, I have an Intel board that uses the company's 82579V.
ButchCassidy
From some Google searches people have had success fixing this issue by updating the drivers. I would start with Intel chipsset drivers. Can you post your setup?
Megalith
24-bit/48kHz
Staff member
Summary
Operating System
Windows 8.1 Pro 64-bit
CPU
Intel Core i7 3770K @ 3.50GHz 53 °C
Ivy Bridge 22nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 1064MHz (9-11-11-31)
Motherboard
Intel Corporation DZ77RE-75K (CPU 1) 43 °C
Graphics
S27C750 (1920x1080@72Hz)
DELL U2311H (1080x1920@60Hz)
4095MB NVIDIA GeForce GTX 680 (EVGA) 42 °C
Storage
238GB SAMSUNG SSD 830 Series ATA Device (SSD) 40 °C
0B SAMSUNG HD204UI ATA Device (ATA)
Optical Drives
HL-DT-ST BD-RE BE14NU40 USB Device
ELBY CLONEDRIVE SCSI CdRom Device
Audio
CA DacMagic Plus Audio
According to the Intel Driver Update Utility, all of my drivers---aside from audio and ethernet---are up to date.
