rezerekted
- Apr 6, 2015
And people wonder why I don't like Microsoft very much.
Every time I go back in there Windows 10 is magically checked again.
Fuck you, Microsoft.
+1
Microsoft removing functionality is a real problem, and is why my media center PC will never be upgraded to anything past Windows 7. I not only have a 4 channel cable card tuner, but an Xbox 360 connected to it as an extender so I can watch live TV, recorded shows and movies on a 2nd TV.
What crap ? I don't remember having to do anything with Vista post SP1 to get it working perfectly fine.
How much do you want to bet that as aggressive as Microsoft is being with the Windows 10 update that there's tons of people that still don't have a clue and assuming that the free update is over on July 29, 2016 will wonder why they never knew it was an option?
Ugly tiles on the start menu that launch functionally crippled phone apps?
Or Visual Studio 2015 with jump lists on the tiles that's in the latest build.
In any case it's pretty obvious you don't use 10. That's fine, but you're trying to make too fine a judgement on something you're not experienced with enough to make such fine judgments.
Like the whole BitLocker key must be stored one OneDrive thing you went on and on about that simply isn't true.
I swear, the only thing holding me back from Linux is I'm a gamer (Battlefield 4, Path of Exile, Starcraft 2, etc). How is gaming in Linux these days?
Windows 10 is the biggest beta OS Microsoft ever released. They want everone to use a beta for testing purposes. Tell me one OS ever released by MS with a feedback built in. Not one thank you, only ones released with feedback were betas or public betas. So far I have seen Windows 10 on about half the machines I fix and so far some people like it but most people hate it. The start menu is not really back period all they took was the start screen from windows 8.1 and put it in a menu. Still no all programs at all. Pin to start does not goto menu but the big blocky tablet menu. I saw one computer in that over 100 programs installed it was a total nightmare trying to organize things.
This path MS is going down is going to hurt there bottom line even more. Businesses are not happy about windows 10 at all for security reasons. It's funny MS made more money when they trusted users back in the 90's when you bought the software put in the key and there was no activation.
Why more poeple switch to other platforms beause MS has lost the trust users had. Other platforms seem to listen to users because there the bosses of there computer.
Man I don't understand the hate for windows 10. People just find a way to hate no matter what. I hated and hated windows 8 because it deserved it, but windows 10 hands down is the best windows to date I have used. There is absolutely no issues I have and it runs fast and fluid and everything works. If there is something specific that you need and it does not function with windows 10 I understand. But you don't wanna upgrade just because bad taste windows 8 left in your mouth, you could not be more wrong. Windows 10 is more than dx12 games, that is the least of any reasons to upgrade.
I liked Windows 10 but once I use four monitors total and when I turn any off to increase my focus I can no longer enable it from windows... I have to go into nvidia control panel. Not sure why it does that.
Windows 8 doesn't have that issue for me.
I noticed the update thing also but if you select show availible updates then ok it will install them.
Does anyone know if the Cisco VPN issue has been resolved? Does windows 10 work well with nvsurround with proper task bar placement?
I'm sure this has something to do with something.
In other words, you've got nothing.
Point me to where I said it "must be stored on OneDrive". I'll wait. Meantime, defaults matter. By default, people are using a Microsoft account because MS has intentionally made the local account option hard to find during setup. And by default when you enable BitLocker, the key is stored on OneDrive.
http://windows.microsoft.com/en-US/windows-8/bitlocker-recovery-keys-faq
https://news.ycombinator.com/item?id=8546524
https://www.reddit.com/r/crypto/comments/3f0j44/windows_10_backs_up_your_bitlocker_recovery_key/
OneDrive is onboarded to PRISM
http://cryptome.org/2014/11/ms-onedrive-nsa-prism.htm
If you think that's bad.
http://tech.slashdot.org/story/15/1...ow-uses-windows-10s-start-menu-to-display-ads
I seem to recall Microsoft apologists saying this would never happen and we we're a bunch of conspiracy theorists.
Ever since I heard they were pushing the spy stuff into win7 I just disabled windows update. Not like my machine is internet facing anyway. I strictly use it for gaming so it does not really go online much.
If you are not on the internet, then how could it possibly spy on you?
A little googling, and that stuff can be disabled. The downside is it disables Cortana too, which I wanted to try...
http://hardforum.com/showpost.php?p=1041881190&postcount=35Remember when a subscription based Windows 10 was the biggest lurking concern about the "gotcha" we'd be looking down the barrel of in exchange for the upgrade being "free".. And MS comes up with this.
Learned today that if you enable Bitlocker encryption on your drive, the key is nabbed by OneDrive. The hits just keep coming.
Microsoft is being Sneaky but it is easy to disable the update. It is hidden as part of the optional updates list. If when you first start Windows Update, all you see is this:
Go ahead and click on "Show all available updates"
Uncheck the "Upgrade to Windows 10" box
Then select the updates you want to install
Remember YMMV HTH
Thanks for that I will give it a try. Honestly I didn't care enough to try any of this but now it seems like my updates are failing to install to get me to upgrade to Windows 10. Love how I get a timer to either confirm the upgrade or reschedule before it automatically starts the install.
If by working perfectly fine meaning unable to play games and taking 15 minutes to boot... You could alleviate this a bit by disabling, a couple somethings, I forget now.
Then there's the infamous, hey Vista locked up and you had to force it off, now it's gonna take 30 minutes to boot....
oh and the SLOWWWWW network issues, shall I continue?
Maybe I was just asking too much, but once I updated to 7/8 on all the Vista machines, all those issues never occurred again.
Games were fine by SP1, IME. Boot time wasn't bad either. There were networking issues, but, as I recall, they were gone before 7 came out. I thought they were gone no later than SP1.
If you took 30 minutes to boot, you had serious issues above and beyond Vista.
