AnIgnorantPerson
- Jan 10, 2019
I have never used VMs before. I need to run some programs that won't run on Windows 10 like netlimiter. How do I do this?
how does that make netlimiter work in Windows 10? Someone said earlier on this form I can run netlimter in VM so I dont have to use the newer version. That doesn't sound like it would workYou install the VM software of choice, such as VMWare Player, and then use the .iso of the OS you need, maybe Windows 7, etc. It's a very simple wizard that walks you through setting up the VM. Then, you treat it as a separate computer.
If this is the program you want to run, then it looks like it is fully compatible with windows 10 !
https://netlimiter.com/products
https://en.wikipedia.org/wiki/NetLimiter
Sounds like they want to run an older version of netlimiter.
Yea I own and like net limiter 3. I really loathe netlimter 4.
I dont get how a windows 7 program cant run on 10. Can any of you explain that?
You'd need to put it in a VM, as above, and you'd need to route all internet traffic through that VM.
The first part is absurdly easy- the second part I know that you can do, but it's not something I've done myself yet, and definitely not with Windows.
And probably not something I'd recommend with the way Windows 10 likes to restart your computer whenever MS feels it's time to push an update.
