Hey guys,
Having a little issue with Winamp and Remote Desktop Connection. This has happened in the past, but I am going to try and reiterate now that I know more about it. Normally before I go to work, I turn on my computer, Winamp, setup the server, and then go to work so if I want to I can listen to it from here. I connect and use my computer using RDC. I was working on my computer trying to download a file there, and I had to reboot... so I do.
Now, here's the issue. Whenever I'm logging in to a fresh boot of Windows, and I try to play audio, I get this error message:
waveOut output v2.0.2a error
There is no driver installed on your system.
Error code: 6
Now, I never get that issue if I turn on and then access while it's already on... however if I'm logging into Windows just after a reboot [and it processes everything in the startup.ini file] I get that issue.
Is there any fix around this, or any way I can bypass it? I know damn well there is an audio driver.
Error code: 6
