I'm having some trouble trying to establish a solid network connection between two aging windows 98 machines.
Background info:
*There are two machines: FRONTDESK and SERVER
*The network had worked fine before replacing SERVER with a slightly newer pc and formatting it.
*Both machines are running Win98 SE, the network settings being the same for each: everything is set to default/set to auto acquire.
Ipconfig /all was run, and this was what came up:
SERVER
FRONTDESK
It appears as though the SERVER isn't retreiving an IP address from the router, and so it isn't able to really browse the internet. Could this be affecting local network browsing as well? I'm really not sure at all. Also, if these two machines are both Win98, why would the ipconfig appear different, showing slightly different info?
Problems:
*The network between the two exists, sort of. Half the time, the two won't connect, and when they do, browsing/transfering files takes eons.
*The second machine, FRONTDESK, is able to browse the internet just fine. However, SERVER appears to have an internet connection (it will contact pages, load the titles in title bar), but it will not load pages, it just takes too long.
I realize I'm probably missing some key info. Just let me know and I'll supply it.
Background info:
SERVER
FRONTDESK
Problems:
