Nope
It's pretty easy, you just go to microsoft.com...You are wrong. I have an upgrade package right in front of me with both 32-bit and 64-bit disks and it only came with one key and I know for a fact the key works on both because I installed 64bit first but their were no drivers for the nic on the mobo for win 7 64 bit so I had to install the 32 bit version.
Now to the op how are you going to purchase just a key? Most online stores that sell keys only are not legit, pretty much anywhere besides MS or one of its partners that sells keys only to the public isn't legit.
$29.99, little sister did it just a few weeks ago.
They email you a key, made her a copy of my retail disc.
32/64bit, doesn't matter, keys are universal in that regard.
I know a normal windows 7 serial key will work for both the 32 bit or 64bit installation of its respective OS. but is the same with the upgrade version?
If I purchase a win7 pro upgrade 32bit key, will it work for a 64bit install?
Windows 7 product keys do not care if you have 32-bit or 64-bit. As long as it matches the edition you are trying to activate. e.g. W7 PRO PK should only be used to activate W7 PRO.
yeah im gonna buy the student upgrade version from digital river. Unfortunately Ive already purchased a 64 bit version and it caps at 1. I can still buy a 32bit, and I wasnt sure if upgrade versions were some reason locked down to only the architecture the key was for. I dont see why the would be since the normal versions are not
+ it can matter if it's OEM, Retail or OEM SLP (?) or whatever it's called.
