In windows explorer, when you click the left side menu folders, it automatically expands them and shows the subdirectories on the left side...in 2k, you click the folder and it lists content on the right, you double click the folder to expand its subfolers on the left. I really don't like the auto expand feature of xp, but I can't find a way to turn it off. I tried messing with the 'single click to expand folder contents' option in 'folder options' however that only affected the right side of the explorer window, not the left. Is there any way to turn this 'feature' off?
