Win Server 2012 R2 Help
Discussion in 'Operating Systems' started by IceDigger, Oct 27, 2015.
  1. IceDigger
    IceDigger [H]ardForum Junkie
    10,488
    Feb 22, 2001
    Fooling around with a free win2012 r2 server and must have messed something up since I can't see it on the network anymore. I just can access the network shares through typing in its ip address but typing in its name it doesn't come up anymore.
    I have it setup as just a simple workgroup and was fooling around with vpn since I wanted to learn that, I installed it and uninstalled it and now I can't see it on any of my computers attached to the network.
    I also cannot remote login into it anymore with either the name or the ip address.
    Any ideas?
    Boy I feel dumb.
  2. ND40oz
    ND40oz [H]ardForum Junkie
    11,196
    Jul 31, 2005
    DNS still configured correctly?
  3. IceDigger
    10,488
    Feb 22, 2001
    I'm not sure, how would I check that?
    My knowledge of windows server edition is nill.
    Its still setup to use the workgroup I think.
  4. ND40oz
    11,196
    Jul 31, 2005
    Network settings, is it grabbing DHCP or did you configure a static IP? Sometimes VPNs want you to change DNS to use one of their DNS servers and that can cause local network issues.
  5. IceDigger
    10,488
    Feb 22, 2001
    I did set it up as static, both for the ip and the dns.
  6. Delemon
    Delemon Limp Gawd
    217
    Nov 28, 2006
    Did you perhaps turn off network discovery? Double check in Network and Sharing Center.
  7. Demon10000
    Demon10000 [H]ardness Supreme
    4,502
    Aug 20, 2006
    Start by checking that -- can DNS resolve the machine you're trying to get to? From a command prompt, try to ping it and see if you get an IP back.
    What is the IP, Gateway, and subnet mask of both machines that you're trying to use?
  8. IceDigger
    10,488
    Feb 22, 2001
    That was it. Its always the simplest things you never check.
    I feel like such a dummy.
    Someone post a Sanford and son picture :D
