I am having trouble extracting .zip files to certain directories on Windows 7 (64bit). Some applications I have installed and want to unzip them inside a specific directory per instructions in the .zip. However, I have been getting a "Don't have permission" or "Can't create directory" error when I try.
It happens on WinZip 14 and WinRAR both, so I know the zip program is not the cause. Also, I CAN extract the same .zip archive to my Windows 7 desktop just fine. But certain directories in my "Program Files" folders don't seem to allow me to do so. I thought at first setting WinZip to "Run as Administrator" would work, but it did not.
Right now I am at a loss as to what Windows 7 is needing me to do for permissions or how to fix this. Since I know the archives are good and extract fine to my desktop and it is only certain directories like my Program Files folder that it does not extract to with those errors it would seem some sort of access needs to granted. I am running using my Administrator account that was created during Windows 7 install.
Has anyone seen this too or knows what the cause may be for the failed .zip extractions?
Thanks,
Jeff
Thanks,
Jeff
