I installed Win 7 64 bit version Beta today on a 40Gb hd I had. I did a format and clean install. Everything seemed to go well until I tried to connect to the internet. The only option it gives me is broadband and it seems to be dialing up. If I try to install the 4.1 driver it doesn't work so the adapter is not recognized by Win 7.
Any suggestions on how to get internet access? Maybe I should try the 32 bit version instead?
