Win 11: Old PC copy over to new PC?
skypine27
What's the best way to do this:
Say you have your old, trust worthy home built system with all your files pics music bookmarks passwords games etc running Win 11 Pro. Youre tired of building PCs at this point and you buy a fancy, new OEM PC with Win 11, and all the associated bloatware, preinstalled. And you have 2 x monitors.
Is there anyway to "copy" all the stuff, settings, files, bookmarks from the old PC over to the new one via wifi or network? The new one is going to have a new mobo, CPU, hardware etc so something like a Macrium Reflect Free disk image restore wouldnt work well.
What to do? Whats the easiest way to make your new PC look and feel like your old one?
B00nie
Unfortunately the Windows registry makes this pretty much impossible. All you can do is a 'dirty' migration where you copy your OS from the other computer and hope Windows can sort itself out on the next reboot. On most other OSes you would just copy your applications/home folder and be done with it.
pendragon1
Extremely [H]
clone it, let windows setup the new hardware. if using both systems, change the system name and the windows key to the oem key. then remove the old drivers and install new ones for the correct hardware.
ive transplanted/clones the same ssd between 12+ different configs, desktop and laptop, without issues. 10/11 adapt to hardware changes very well.
philb2
Laplink. I used it and it migrated almost all software and settings. (I handle data in a separate drive partition.) I had to reinstall only Office and Norton Security software.
dbwillis
That's one reason I do my main, home machine as a vm, I airways change the physical machine (like every 2 months), just need to copy the vm from old to new
GoldenTiger
Windows handles transplants very well nowadays. You can probably just copy the drive with an imaging program like you mentioned and be fine.
