Will NZXT Kraken RGB 3x120mm will be ok for 10850K/10900K?
D-EJ915
Depending on what kind of load and overclock you run on it the D15 is fine, I would use it first and see if it is inadequate then worry about upgrading. The X73 will work fine on it as well if you do need more brute force cooling.
mgty23
I know but AIO water cooling will be useful on future too. So
NZXT Kraken X73 RGB 3x120mm will be fine with 10850K or 10900K?​
Pc will be used for games only. No prime95 or other similiar apps.
mgty23
Thank you dear users for helping and answering. Really great peoples here . Reall appreciate it. I love you :) hehe
