Will Nvidia RTX runs hot?
Discussion in 'nVidia Flavor' started by trick0502, Sep 18, 2018.
  1. trick0502
    trick0502 [H]ardness Supreme
    5,153
    Apr 17, 2006
    with the reference card being a dual fan cooler and a lot of the AIB cards being 2.5-3 slot coolers are we to assume these cards run hot? And maybe use a lot of power? Do we have a rx 290?
  2. MrC4
    MrC4 [H]ard|Gawd
    1,308
    Feb 10, 2010
    Why don't you wait a few hours and you will know for sure.
    DF-1, Armenius, Maddness and 4 others like this.
  3. Maddness
    Maddness [H]ard|Gawd
    1,209
    Oct 24, 2014
    Probably seeing as it is such a large chip. Although the voltage is around the same as Pascal. Guess all will be revealed shortly.
  4. N4CR
    N4CR 2[H]4U
    3,836
    Oct 17, 2011
    Yeah my guess too. I think they also pushing the architecture more this release, bigger chip is also harder to OC.
    Saw someone getting a paltry 170MHz clock increase. I guess no one will bitch about the shitty OC headroom (Aka some later AMD cars) because they are fastest solution and muh nvidya, so it's irrelevant all of a sudden lol.
  5. Trimlock
    Trimlock [H]ardForum Junkie
    15,157
    Sep 23, 2005
    we know nothing about the cooler efficiency, other than they finally got rid of the damn blower.
    Know this, it is a 250watt card that probably pulls much more when it boosts, the gpu die size is massive, its using newer faster memory and its in a spot on the motherboard that places it at the worse possible area for air flow (not to mention the physical size blocks good airflow too).
    It will be hot.
  6. singe_101
    singe_101 2[H]4U
    2,087
    Dec 17, 2005
    For the 2080 Ti could the fans stay idle for some modern games at 1080p, 60+ FPS and never dipping below?
    I doubt anyone will test that but it gets 130 FPS in Deus Ex: Mankind Divided 1080p.
