Wickedout2011
- Sep 1, 2011
I have Antec EA 750 PSU and was just wondering if it could handle all of that. One reason I was going to get another PSU for that purpose alone. If I don't have to I won't! Thanks!
I don't see why you would want to do that. Your current PSU is perfectly good.I'll probably replace it in Jan. 2012 with a big 1000 watt PSU.
Your PSU can run any SLI or Crossfire system in the forseeable future, with the exception of perhaps highly overclocked x79 SLI/crossfire systems.
Nice to know. I don't see myself going x79 anytime soon.
I don't know where you heard that, but I can tell you with 100% certainty that LGA2011 CPUs will not draw anywhere near 200W at stock speed.The reason why I say that is because x79 looks to be a power hungry beast, with estimates on the CPU power draw to be up to 200 watts or higher.
Wrong. The PCI-E standard specifies maximum power draw per connector and per slot, not per card. There is nothing preventing a GPU manufacturer from putting more than two PCI-E connector sockets on their cards, as some have already done. In any case, the theoretical limit for a PCI-E 2.0 card with two connectors is 450W; 150W each from two 8-pin connectors and 150W from the slot. No current video cards come close to that number.Any single graphics card that exceeds 250 watts will be exceeding PCI-E specifications, and manufacturers don't want to do that.
Reading the thread with the melted 24pin connector should have cleared all that up for you..I was referring to the statement I made above with a heavily overclocked x79 system.
I thought maximum power draw from the slot was 75 watts? And I don't think most people (including hardcore ones) would like to see a single GPU require two 8-pin power connectors. I also thought there was an official board limit of 250 watts for a single stock GPU? Or I must have misread that somewhere. I mean, nVidia could have released a fully enabled GTX 480, but they didn't want to exceed the power draw limits of a 6-pin and 8-pin connector.
